Coming Soon
How to Rip DVD with DVDFab DVD Copy?
You have a DVD disc and you want to rip DVD content onto your hard drive for backup, you can try out DVDFab DVD Copy for free, and everything will be done easily and quickly. Next is a simple tutorial about how to use DVDFab DVD Copy to rip a DVD.
Step 1: Start up DVDFab 9, choose Copy option
After downloading and installing DVDFab 9, start it up and choose Copy option on its welcome screen, to come to the following Copy interface.
Step 2: Load in DVD and set up
Now insert the DVD disc into optical drive for DVDFab to import it in. A couple of seconds later, the DVD movie will be in, and the longest movie title will be selected by default. And you can freely change audio tracks and subtitles. For the output type, you can choose DVD5 or DVD9. Particularly note that you can rip DVD onto hard drive of your computer with two modes. One is choose the folder icon behind the “Save to” box to select a directory on your PC for saving the output DVD folder/fileset; the other one is choose the image icon behind the folder icon to select a directory where you can save the output as an ISO image file. Choice is yours. By the way, you can preview the title in real time in the right half part of the interface.
Step 3: Start ripping process
Click Next button to the next interface. Then hit Start button to start ripping process if everything is OK. During the ripping process, you can view detailed progress info and preview the progress with real time images. If you want, you can set your PC to auto shut down when all tasks are done, or set the program to auto exit.
OK Done. More info about DVDFab DVD Copy can be found at: http://www.dvdfab.cn/dvd-copy.htm
  • Discount
    FAB-WHN-OFF
    Feb 27, 2017
    for Buying
    The Universal Master Key
    Price: $60 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $79 Buy Now
