Digitalize Your Stuff by Ripping DVD with VLC
Summary: Have you tried the VLC ripping DVD feature? Want to master how to rip a DVD with VLC? Know any other alternative to rip copy-protected DVDs and digitalize them for mobile playback? You will get all desired answers in this post.
Want to rip DVD with VLC for digital playback on your mobile devices? Know any other reliable alternative to rip copy-protected DVDs free and easily? Even though we don’t see many DVDs these days except for games and movies, there may be times when you will need to rip a DVD and store all its contents on your computer. Be it extracting data from any DVD or digitizing your DVD collection to free up physical space, VLC Media Player can do the job well. Today we are going to tell you how to rip a DVD with VLC Media Player. More importantly, we are also going to tell you the best-ever alternative to the VLC ripping DVD.
1. VLC Media Player Ripping DVD: Everything You Want to Know
VideoLAN VLC Media Player is a free and open-source media player which can play most popular multimedia formats. Besides being a media player, it also has several useful tools like converter, filters, downloader, and many more. VLC Media Player is available for all platforms, including mobiles. Below are some questions that might haunt you when it comes to VLC media player ripping DVDs.
Can VLC Media Player Rip DVDs?
Yes, the VLC media player can easily rip DVDs and convert them into whichever file format you want. The ripping DVD VLC process is simple, and we are going to take a look at how you can rip a DVD with VLC Media Player.
How to Rip a DVD with VLC for Free
You can digitalize all the files present in your DVD by following these simple steps.
Step 1: Install VLC from its official site and open it.
Step 2: Insert the DVD that you want to rip to digital formats.
Step 3: Click on the Media menu present at the menu bar on top of the window. A drop-down menu will pop up. Click on the Convert/Save.
Step 4: The following window will pop up. Select on the Disc tab, and you will see this window.
Step 5: Select the type of disc that you want to rip. Then select the DVD or a VIDEO_TS folder that you want to rip by clicking on Browse.
After that, you can make some customizations like starting position, audio tracks, etc. If you click on the checkbox that says Show more option, a new list of customizations will open up.
Now that you have made all the customizations, click on the Convert/Save present below to continue to the next step.
Step 6: You will see this window above where you need to provide the final instructions to VLC. Select the place where you want to save the video by clicking on Browse present beside the Destination file textbox.
Click on Profile. A drop-down menu will open up where you need to select the format of the output. You can click on the other checkboxes if you want, else ignore it.
Press on Start, and that is it. Now sit back and relax while VLC converts the file for you. You will find the files in the destination where you chose to save them.
Can VLC Rip DVD to MP4?
MP4 is a popular video format, so this question may come to your mind. The answer is yes, you can. If you look at the screenshot provided above, you will see the list of formats, and MP4 is present there.
Can You Rip Multiple DVDs in VLC?
Sadly, the answer is no. You can select only one DVD at once. That means it will take you a long time to wait for the VLC ripping DVD.
Limitations of Ripping DVD with VLC
There are some other limitations when ripping DVDs with VLC. Nowadays, almost all commercial DVDs have special encryption to prevent people from copying the data. Most of the time, VLC cannot break through such encryption. If you want to remove DVD copy protection, you shall turn to professional decryption tools.
Another problem is that you do not get that many options to convert to. Most of the popular formats are available, but there is a chance you will not get the desired format.
Also, you do not have many customization options. You cannot choose the quality of the video. You can do that manually by fiddling with the converter, but the process is complex.
VLC is an application that we keep on our computer anyway as it is a really good multimedia player. So, it is good for you if you simply want to rip videos from DVD without caring about the quality or size. However, if you are serious about ripping videos and customize them via ample options, or want to break the encryption of DVDs, then you will need to rely on dedicated conversion tools. That is where DVDFab DVD Ripper comes in. It is the best alternative to VLC ripping DVD.
2. DVDFab DVD Ripper: Best Ripping DVD VLC Alternative
DVDFab DVD Ripper is the best-ever dedicated DVD Ripper full of peerless features. You can rip videos for DVDs in more than 600 audio and video formats. DVDFab will automatically detect if any anti-copy encryption is present in the disk and decrypt it automatically.
You get tons of customization features – resolution, codec, video quality, bit rate, frame rate, etc. You can also extract subtitle files in the form of.SRT. You also get additional video editing tools like cropping, trimming, merging, rotating, adding text, image, or subtitles, adjusting brightness and contrast, and many more.
The coolest thing is that you can even rip multiple DVDs at once! If you can insert multiple discs simultaneously, you will have no trouble ripping them at the same time. Ripping files from DVD can be slow. However, if your PC has the processing power and necessary hardware configuration, you can utilize DVDFab DVD Ripper’s GPU hardware acceleration technologies to boost up the conversion speed. Above all, DVDFab DVD Ripper also provides you with an AI feature (Enlarger AI) that can AI upscale video from 480p to 1080p.
DVDFab DVD Ripper is available for Windows and macOS. You can download the tool for free. The free version has features good enough for simple conversions. A lot of more features are available in their premium version. As a trial, you will be able to rip three discs using its premium features, after which you will need to pay for premium features.
You can buy their packs on a monthly or yearly basis which gets renewed automatically. Else, you can also go for their lifetime bundles.
How to Rip DVDs with DVDFab DVD Ripper
Ripping DVD VLC might not work when your DVD disc contains copy protection. No worries! DVDFab DVD Ripper comes in handy. You can use this best professional DVD Ripper to store all your content from DVD to your computer, even mobile, easily by following these steps.
Step 1: Run DVDFab DVD Ripper and load DVD source
Free download DVDFab DVD Ripper and choose the Ripper module when it runs. Click on the + sign to add the ISO file or folder or insert the DVD disc into the optical drive.
Step 2: Choose one profile and customize the output video
Choose the file that you want to convert by clicking on the Choose Other Profile and selecting Format, and then click on the Video. Suppose you want to extract subtitles in the form of.SRT files, you can do that by selecting Subtitles in Format. Want to convert DVD to MP4 on mac for perfect playback? Ask this best free DVD Ripper for help!
You will see lots of options to customize the output. Hit the Wrench icon (for Advanced Settings), you can select audio tracks, codec, subtitles, and many more. When you click the Pen icon (for Video Editor), you can retouch your video via lots of editing features, thus making it personalized.
After you are done, select the directory where you want to keep the output and press Start located on the bottom-right side of the window. Compared to VLC ripping DVD, DVDFab DVD Ripper outshines it because of its customized options.
Step 3: Start to rip DVD free and fast
After finish customization, click the Start button to rip the DVD instantly. No need to wait till DVDFab DVD Ripper completes its job. You can pause and continue the conversion process whenever you want to. If the process takes a lot of time, you can opt for the computer to shut down or hibernate automatically once the process is completed. Actually, due to GPU H/W, the whole ripping process will be finalized in 5 minutes.
Final Words
The VLC media player is a very useful program, and everyone should have it. Is VLC ripping DVD available? YES! It has lots of basic useful features, and they can come in pretty handy for doing simple tasks like converting videos, ripping DVDs, or downloading videos. But ripping DVD with VLC is not the optimal solution to get digitalized videos for mobile play. How to fix this problem? Turn to DVDFab DVD Ripper. It has so many marvelous features that it will take another article to just talk about it. So, do give it a try.
