The Best 4K HDR Monitor to Buy in 2024
Summary: With the rise of the gaming industry, the demand for 4K HDR monitors and laptops has increased. And if you are into gaming, then having a 4K HDR gaming monitor is a must. Below are some monitors that can qualify as the best 4K HDR monitor. Read below to know more.
- • Capable of playing local videos, DVD/Blu-ray/UHD disc and streaming videos
- • All-In-One platform of streaming playback
- • Online playback video in FHD 1080p video quality and EAC3 audio quality
Dell UltraSharp U2720Q
the Dell UltraSharp U2720Q can be a good option for the best 4K HDR gaming monitor and has got various major upgrades, thereby making it perfect to use as an everyday monitor. It comes with support for proper VESA DisplayHDR 400 for entry-level HDR. In addition to this, it has a USB-C port with power delivery that users can use to charge USB-C smartphones and laptops.
The LG HDR 4K monitor rival does not have a good high refresh rate as compared to other 4K monitors, but if you are looking for a normal-looking 4K monitor that is enough to suffice your basic gaming needs, then this is the monitor to purchase. The U2720Q shares come with the same design as its predecessor U2718Q, including its super thin bezels.
Apart from this, its IPS panel is just good, producing accurate and rich colors along with low black levels and enhanced contrast. Moreover, the newly-added HDR support for U2720Q means users can actually let those colors sing in compatible games, as well. To add more to the list, this monitor is a good rival to most LG 4K HDR monitors and screens. It has a height-adjustable stand and is a truly great 4K monitor.
Specifications
- Resolution: 3480x2160
- Screen size: 27in
- Refresh rate: 60Hz
- Panel: IPS
- Price: $575
- Extras: VESA DisplayHDR 400, height-adjustable stand, USB-C,
Asus ROG Swift PG32UQX
Being one of the most expensive monitors in the industry, the Asus ROG Swift PG32UQX is something that asks you how much you are willing to spend on a monitor. With this said, the display is an excellent 4K gaming monitor.
Response times could be higher but almost everything looks glorious at 4K 100fps+. Also, the accuracy and color coverage is truly top-tier. The ROG Swift PG32UQX is created to last as well, with a stable, reliable, sharp-looking, and adjustable metallic stand.
The major cost of the monitor is due to the Mini LED backlighting. This is a generational enhancement on the crude edge backlighting users can see on most IPS displays, stuffing thousands of small LEDs all over the whole panel for a great mixture of high contrast, high brightness, and bleed-free backlighting consistency.
If you need an IPS display that offers performance similar to OLED displays, this is the option. The brightness advantages are of specific use to games that support HDR, as the display can tip more than the 1000cd/m2 mark on bright spots without accidentally lighting up any contrasting dark regions.
Specifications
- Resolution: 3840x2160
- Screen size: 32in
- Refresh rate: 144Hz
- Panel: IPS
- Price: $2,700
- Extras: Height-adjustable stand, Nvidia G-Sync Ultimate, VESA DisplayHDR 1400, customizable OLED mini-display
Asus TUF Gaming VG28UQL1A
Making higher-end gaming features accessible on 4K displays, such as 144Hz refresh rate, can easily increase price tags. The Asus TUF Gaming VG28UQL1A might not be as inexpensive as the 60Hz displays in the industry, but taking into consideration the fact that it manages a complete 144Hz and many other qualities apart from this, it is a good option as a 4K HDR monitor.
The only drawback is the tendency towards oversaturated colors, something that manual settings adjustments or calibration can help with. But at least users can never accuse this display of being dull, and its 98.8% sRGB gamut coverage and contrast ratio of 1032:1 is added feather to the hat.
While playing heavy games, if you have a powerful enough computer to level up then the TUF Gaming VG28UQL1A will entirely deliver on its promise of super-sharp and super-slick 4K. It comes with some nice extras as well, such as HDMI 2.1 input and a fully adjustable stand.
Specifications
- Screen size: 28in
- Panel: IPS
- Price: $800
- Extras: Nvidia G-Sync Compatible, AMD FreeSync Premium, height-adjustable stand, VESA DisplayHDR 400
BenQ EL2870U
4K HDR gaming monitor often has a huge price tag, but the BenQ EL2870U is an example that shows you do not need to shell out a huge amount for a great 4K display. It does not have such features as compared to others in the list, such as a height-adjustable stand or a high refresh rate, but its 28in TN panel is still can displaying vivid and rich colors to make your games look stunning.
It is not the brightest monitor in the industry, with a maximum 280cd/m2. Hence, users will possibly have to have it on max settings if they play games or work in a specifically bright room. Although, under normal lighting conditions, this shall still be plenty for daily use, and the company’s clever ambient light sensor can adjust the brightness automatically to help reduce eye strain and ensure it is always suitable for your surroundings.
The monitor also has AMD FreeSync support for flawless tear-free gaming, and while it is not a legitimately certified G-Sync Compatible display, Nvidia graphics card users shall still be able to make use of its adjustable refresh rate tech by allowing it in their Nvidia Control Panel. In short, it is a great display for the price it offers.
Specifications
- Screen size: 28in
- Panel: TN
- Price: $270
- Extras: HDR10 support, AMD FreeSync, blue light filter, ambient light sensor
Philips Momentum 436M6VBPAB
If you are fond of playing games in your living room, then you might be looking for a 4K gaming display that can double up or replace your living room TV. The Philips Momentum 436M6VBPAB is a huge 43in gaming screen that is one of the best 4K gaming monitors in the industry. Its refresh rate may be limited at 60Hz, but the display still has a wonderfully precise MVA panel, along with top-notch HDR support.
Certainly, with its certification for VESA DisplayHDR 1000, it is just as punchy and bright as other options in the list. Even better, its adjustable refresh rate tech for flawless tear-free gaming is not restricted to just Nvidia graphics cards. Also, its adaptive sync support works with both Nvidia GPUs and AMD alike. It is a great option no matter what is within your present PC.
In addition to this, the Ambiglow tech offers you a clear RGB lighting effect surrounding the edge of your display, matching the dominant colors onscreen to assist elevate your experience beyond the screen borders. If you enjoy that kind of feeling, it is a nice option worth trying.
Specifications
- Screen size: 43in
- Panel: MVA
- Price: $850
- Extras: VESA DisplayHDR 1000, Adaptive sync, 2x 7W speakers with DTS sound, Ambiglow lighting, remote control
Using PlayerFab All-In-One for Best Viewing Experience
Operating system: Windows 11/10/8.1/8/7 (32/64 bit)
Price: $169.99 (lifetime)
If you are looking for the best alternative to VLC Media Player, PlayerFab All-In-One is definitely your top option. It contains powerful functions enabling users to enjoy the best viewing experience, no matter you want to play your DVD or watch videos from a streaming platform, PlayerFab All-In-One can satisfy all your needs with high-quality video and audio.
Can a 4K monitor run at 1440p?
Yes. All users need to do is go to Display Settings of Windows and set the Display Resolution to 2560x1440.
Are 4K gaming monitors worth it?
With their crisp & sharp pixel densities and high pixel count, 4K gaming monitors can be brilliant options for daily desktop work. They offer plenty of space for looking at different desktop apps at once, and they also make it much simpler to juggle and see different windows in creative apps such as Adobe Premiere Pro and Photoshop.
If you frequently use these types of apps in your daily work life, 4K monitors are almost certainly going to be worth the additional penny spent as compared to the lower resolution monitors.
Why are lots of 4K gaming monitors only 60Hz?
It all depends on how much bandwidth is accessible in the display inputs of your monitor. It consumes a lot of bandwidth to power a 4K monitor, particularly once you turn on the HDR into the game, and selecting for more pixels often comes at the price of a high refresh rate. On the other hand, DisplayPort 1.4 provides more bandwidth as compared to HDMI 2.0, allowing up to a max of 120Hz with HDR at 3840x2160. Due to this, if you see a 4K display with a high refresh rate currently, there is a high chance it can only manage that rate with the help of DisplayPort. If you connect it over HDMI to your PC, you will only get 60Hz.
Having said that, you just had a look at the best 4K HDR gaming monitor options. Choose from any of the above options and you are all set to take your gaming experience to the next level.
