Best MP4 to MP3 Converter Software in 2024
Summary: Even though a number of users prefer videos when it comes to entertainment, audio files have their own taste. Videos are preferred, but often users want the audio alone. It is handy to listen while doing other tasks and does not drain the battery of your device. This is why users are in dire need of the best MP4 to MP3 converter. Extracting a quality MP3 audio file from an MP4 file needs the best MP3 to MP4 converter. To address this issue, today we provide you a list of the best MP4 to MP3 converters online and offline that you can use. Read below to know more.
Best MP4 to MP3 Converter Software for Desktop
Best MP4 to MP3 Converter: DVDFab Video Converter
DVDFab Video Converter is the best free MP4 to MP3 converter tool. It can convert MP4 to MP3 along with a video conversion feature from one format to another. Let us have a look at some of the features of this tool.
- Supports different audio and video formats
DVDFab Video Converter also supports different video and audio formats and converts them from over 1000 formats. In addition to this, the tool also provides the meta info of the file sources, specifically for TV Shows. This info will be shown and fixed in the output videos, making sure that your media server or media player software can list them clearly for a smooth experience.
- Personalized media parameters
The tool can completely control the output. This can be done easily. Users just need to copy the video and the resulting subtitle and audio stream can be used by them. Users can also modify video parameters as per their needs. They can compress video with the needed size and quality for sharing on social networks or playback on mobile devices.
- Advanced video editor
DVDFab Video Converter provides an in-built video editing feature. Users can also add subtitles or titles with background music or special effects to the video. You can add a premium opener or intro to introduce their video. The tool also allows to crop off unwanted parts, rotate video, trim clips from the video, or merge clips into one.
- High conversion speed
The tool is developed with a spontaneous and easy UI. It offers the best user experience with the help of multi-core, the latest Intel Quick Sync, multi-threading, and NVIDIA CUDA. It can process any video or audio conversion task in a bunch 30x faster.
- Enlarger AI
Using DVDFab Enlarger AI (an AI-powered video upscaling tool), the low-resolution media files can be converted into 1080p, and 1080p media files can be converted into true 4K.
How to Convert MP4 to MP3 Using DVDFab Video Converter?
- Download, install, and launch the tool and click the Converter option on the main screen.
- Upload the source video using the Add buttons.
3. Click the Choose Other Profile >> Format and Device options.
4. Users need to choose MP3.
5. Next, go to the Save to option and click the folder logo to choose the output directory.
6. Tap the Start option to convert video fast and free.
Freemake Video Converter
Freemake Video Converter is a well-known tool with millions of users. If the MP4 file is not copy-right protected, users can convert it absolutely free to MP3 format with no restrictions. The tool also provides a downloader with an extra touch of automation to the process. After converting MP4 to MP3, the tool allows you to transfer the audio to iOS and iTunes devices easily.
Features
- In-built uploader and downloader
- Provides a DVD audio burner and ripper
- Provides customizable conversion presets
- Batch processing
Pros
- Tons of editing options
- High-quality output
- Free
Cons
- Infrequent updates
- Slow conversion
Any Video Converter
Any Video Converter is a converter known for extra amazing features. Rather of just offering only MP4 to MP3 conversion, the speed and performance are enhanced further up through the employment of hardware acceleration, which is 30X faster. In addition to this, the quality of the output file remains intact to the greatest extent.
The tool also provides a downloader at your disposal and also offers support to different websites. Users also get to edit the audio to specific devices such as iPhones, iPads, Android smartphones, and more. Apart from this, users get to edit the audio output by regulating different parameters such as the sample rate, compression level, quality, channels, and many more.
Features
- Hardware acceleration
- Built-in YouTube downloader and editor
- Free audio CD ripper
- Batch processing
Pros
- Provides compression options
- Crisp audio output
Cons
- Asks you frequently to buy the paid version after each conversion
- Adware during installation
Best MP4 to MP3 Converter Software Online
DVDFab Online Video Converter
DVDFab Online Video Converter works the same as the offline version. It offers you a means to convert your MP4 to MP3. This online tool supports different popular formats and is fast & easy. The tool offers the best output quality and is supported on all devices since it works online. In addition to this, the conversion process is completely secure since the tool deletes uploaded video files instantly and converted ones after 24 hours. Lastly, files are processed in the cloud, so there is no need to install software that will occupy your device's memory and computing power.
Features
- Popular formats supported
- Fast and easy
- Excellent Quality
- All devices supported
- File Protection
- Cloud conversion
How to Convert MP4 to MP3 Using DVDFab Online Video Converter?
- Visit the official website of the online creator.
- Click the Choose Files option to select your wanted files.
- Select MP3 as file format and click the Convert option.
- Click the Download option to download the converted files.
Convertio
Convertio not only offers conversion but also integrates Google Drive and Dropbox cloud services. This allows users to import MP4 files and still save the converted MP3 files. In addition to this, users will get a 100MB maximum upload size. Also, users get unlimited conversions every day and a secure process due to the employment of encrypted connections. Users also get high levels of performance and efficiency, thereby making sure that the MP4 to MP3 conversion takes less time and offers output almost.
Features
- Integrated Dropbox and Google Drive cloud services support
- Security and privacy
Pros
- Multilingual interface
- Multiplatform
- High performance
Cons
- No cloud storage
- Limited upload size
CloudConvert
CloudConvert offers support for cloud services similar to the above-mentioned option. What makes this converter stand out is that it allows you to regulate parameters such as the audio quality among other options prior to the final conversion. To be particular, users are free to change the bitrate, audio codec, Qscale, and volume. Also, users get options to trim an audio file to get rid of any unwanted parts.
Features
- High-quality conversions
- Distinct output quality
Pros
- Allows you trim audio files
- Provides a powerful API
- Flexible pricing
- Allows you to adjust various audio parameters
Cons
- Lots of ads
Does converting MP4 to MP3 lose quality?
The converted file could be smaller or bigger, but the quality will degrade either way due to the re-compression process. In simple words, the AAC codec (utilized by MP4) is slightly more effective than MP3 and hence the conversion process can cause a bit of quality loss.
Do YouTube converters give you viruses?
There are many websites available to use for free. The question that concerns most users is that is it safe to use these YouTube converters. In simple words, the answer is “Yes.” It is secure, but some websites might be incompetent and can bring a virus to your PC.
Are M4A and MP4 the same?
An M4A file is a kind of file extension for an audio media file that is stored in a specific format, known as MPEG-4 format, which only contains audio. On the other hand, an MP4 file is a type of multimedia file that has both video and audio. Normally, this is the type of file used to save a film, movie, or video clip.
Having said that, we just had a look at the best MP4 to MP3 converter software. Without any doubt, DVDFab Online Video Converter is the best option available.
