Coming Soon
How to Rip and Convert DVD to MP4 with DVD to MP4 Ripper?
If you want to rip and convert your DVD movie into MP4 video for playback on your iPad, smartphone, etc., you can use DVDFab DVD Ripper to do this, easily and professionally. It is an outstanding DVD to MP4 Ripper. Next let’s have a look at it and how to do the task.
Step 1: Fire up DVDFab 9, choose Ripper option, and load in the DVD
Start up DVDFab 9, choose Ripper option on its welcome screen to go to the Ripper interface. Then insert the DVD you want to convert into optical drive, and seconds later it will be loaded in as showed below. The main movie title is auto selected, and you can change audio tracks and subtitles freely.
Step 2: Select an MP4 profile
Now click to open the profile list, in which you can go to Format to choose one mp4 profile. Any mp4 profile listed here is OK. Just select your favorite one.
Step 3: Freely customize
After the MP4 profile is selected, let’s click Advanced Settings button to set video and audio parameters as you like, or just leave them there since the default configuration work well if you have no specific requirements.
After parameters settings, if you want to resize or crop the video, just click Edit button to open Video Effect window. You can resize the source aspect ratio and the frame resolution; and you can also crop the image for display right here.
Step 4: Start conversion
Alright, now just preview the title in real time to confirm your settings and selections. If everything is OK, go ahead to click Start button to start conversion.
During the conversion process, you can view detailed progress info, and even preview the progress with real time images.
OK. Now leave the rest to DVDFab 9, everything will be done soon. For more info about this DVD to MP4 Ripper, just go to: http://www.dvdfab.cn/dvd-ripper.htm
  • Discount
    FAB-WHN-OFF
    Feb 27, 2017
    for Buying
    The Universal Master Key
    Price: $60 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $79 Buy Now
