We understand it can be annoying when you put your DVD in the disc drive and receive an error message. Then why not consider trying an external DVD decoder?
This article will help you with wonderful DVD decoders to help you remove the copy protection on your computer regardless of its OS or version and play them seamlessly on your gaming consoles, smartphones, computers, or any other platform without needing extra codecs. Let’s get started to find out the best compatible DVD decoder.
How to Decode DVD?
DVD decoders are computer software that lets you access and read DVD discs on other platforms like smartphones and media players. You can easily bypass any encryption or copy-protection and decode the MPEG-2 format to see the original images. Most importantly, you can play the DVD content using the viewing programs available on your PC.
When you buy a DVD player for your PC or Mac, it already has a DVD decoding program. DVD decoders were pre-installed on older computers, but Windows 8 and upwards no longer have built-in DVD decoders in the Windows Media Player. Furthermore, you must seek a different plan if you purchase a second-hand PC or refurbished model without a DVD decoder. Having said that, if it is not there on your PC, you can try an alternative or check any of these best free DVD decoder for Window XP or Mac.
Top 6 Free DVD Decoder for Window XP/11/10/8/7 & Mac
1. DVDFab DVD Ripper — Decode DVD to Digital Files
💻Working System: Windows PC 11/10/8.1/8/7 (32/64 bit) and MacOS 10.10-13
DVDFab DVD Ripper is a compatible DVD decoder that helps you decode and convert DVDs to video and audio formats for seamless playback on any device or media player, including home theatre. It removes encryptions and copy protection from the latest or old DVDs in 1:1 quality with lossless conversion.
free dvd decoder for window xp
Features:
  • Efficiently removes copy protection from old or latest DVDs
  • Converts DVD to MP4 and other 1000 video and audio formats
  • This DVD decoder allows DVD playback on over 260 devices
  • Get 50x faster DVD ripping speed with GPU acceleration
  • Compress video size but preserve quality for any mobile device
  • It supports multitasking mode with a built-in video editor
Win Download
100% safe&clean
Mac Download
100% safe&clean
WHAT WE LIKE
  • Supports latest protected DVDs
  • Enables high-quality lossless conversion
  • Seamlessly rip DVD/ISO/Folder to 1000+ formats
  • Remove Cinavia protection and produce high-quality output
WHAT WE DON'T LIKE
  • The free version has limited functions
How to decode a DVD to digital file using DVDFab DVD Ripper?
Launch DVDFab DVD Ripper and Import the DVD Source
Download and install DVDFab DVD Ripper. Select the Ripper module. Now, either insert the DVD into your computer or drag the ISO file or DVD folder onto the user interface.
How to Decode A DVD with DVDFab DVD Ripper
Select a Profile and Customize the Output Video
Click on Choose Other Profile to access the profile library and select your desired profile. You have the option to convert the DVD into popular digital formats or choose a specific output device format.
Then, access advanced settings and modify parameters. Additionally, utilize the built-in video editor to trim, crop, rotate, add watermark and subtitles, and contrast to enhance video quality.
Initiate the DVD Ripping Process
Determine the file directory where you want to save the output video. You can also enable GPU Hardware Acceleration to expedite the batch conversion. Once you have configured all settings, click on the Start button.
2. WinX DVD Ripper
💻Working System: Windows PC 11/10/8.1/8/7/Vista/XP (32 and 64 bit), and MacOS Sonoma or lower
WinX DVD Ripper is a beautiful suggestion, making its place on our list. This compatible DVD decoder helps decode your DVDs with any encryption or region code, be it CSS, region code, DRM protection, and so on. As it is compatible with all the Windows versions, including XP, Vista, and higher OS, you can encode your DVD docs into multiple formats like AVI, MOV, or MP4 in different video codecs.
Features of this DVD Decoder
  • Rips any DVD, even if it is damaged or scratched
  • Allows rapid 1:1 DVD ripping and conversion
  • Enables you to access and view the files using any device
  • It provides incredible image quality & supports old and outdated discs
WHAT WE LIKE
  • Offers several output formats
  • Allows to adjust video quality
  • Provides custom profiles and editing tools
  • Enables using GPU to increase the file conversion speed
WHAT WE DON'T LIKE
  • Promotes folder backups only
  • Does not have a 2FA
  • It does not allow canceling the ripping process online
3. VLC Media Player
💻Working System: Windows PC 11/10/8.1/8/7/Vista/XP, MacOS X 10.7.5 or later, Linux, Unix, iOS, and Android
VLC Media Player is one of the excellent video players, but only a few know that it is also a free DVD Ripper for Windows 10. Users can try the software to decode and rip their DVDs and keep the information safe on their computers. In addition, with cross-platform availability, you can decrypt the DVD and play them seamlessly by converting it to MP4 file format.
VLC media player - free dvd decoder for window xp
  • Includes subtitle synchronization with audio/video filters
  • It offers numerous codecs & quickly plays most multimedia files
  • Helps do basic video recording and editing
  • Supports a vast range of formats such as audio CDs, DVDs, VCDs, and many streaming protocols
WHAT WE LIKE
  • Free and open-source platform
  • Decode and rip DVD to USB
  • It helps preview the output while converting the file
  • Works seamlessly on multiple platforms like Windows, Mac, and Linux
WHAT WE DON'T LIKE
  • Lacks video editing capabilities
  • Slow and time-consuming process
4. MakeMKV
💻Working System: Windows PC 11/10/8.1/8/7/Vista/XP, Linux, and MacOS X 10.7 or newer versions
MakeMKV is a popular and free DVD decoder for Window XP that helps you decode Blu-ray and DVDs to convert them to lossless MKV videos. Also, the DVD ripping functionality is absolutely free for Windows and Mac users. You can easily rip your DVD to MKV without losing the quality.
windows xp dvd decoder
  • Efficiently reads DVD and Blu-ray discs
  • Retains videos and audio tracks with HD audio
  • It does not require additional software for decryption or conversion
  • Keeps the meta information like audio type, title, track language, and so on
  • Reads Blu-ray discs protected with the newest versions of AACS and BD+
WHAT WE LIKE
  • Simple and easy to use
  • Easily rips encrypted DVD discs
  • Completely free software
  • Convert as fast as the drive reads the data
WHAT WE DON'T LIKE
  • No hardware acceleration is available
  • Results in issues like the incompatible format
5. K-Lite Codec Pack
💻Working System: Windows PC 11/10/8.1/8/7/Vista/2003/XP (32 and 64 bit) only
K-Lite Codec Pack is a Windows XP DVD Decoder that lets you open DVDs and Blu-ray discs without any difficulty. K-Lite Codec Pack works seamlessly on all Windows OS versions from XP and above. While many versions of the K-Lite Codec Pack are available, you can start with the Basic version.
  • Free and lightning-fast program
  • The user interface is simple and easy to use
  • Install all codecs and tools
  • Offers numerous video and audio formats
WHAT WE LIKE
  • Easy to use with consistent performance
  • Useful and fail-proof player
  • Never hangs or crashes ever
  • Easily upgrades the existing player
WHAT WE DON'T LIKE
  • No repeat, i.e., loop button
  • Automatically sets itself as the default player
6. AnyDVD
💻Working System: Windows PC 11/10/8.1/8/7/Vista/XP SP3 (32 and 64 bit) only
AnyDVD is a DVD decoder for Windows that helps remove DVD restrictions silently in the background, making it easier to use other programs without any hassle. While encrypted DVDs are hard to read and play, AnyDVD easily decrypts them to access different media players. Luckily, with a free trial period of 21 days, you can try the program to check its functionality.
compatible dvd decoder: anydvd
  • Automatically adjusts your monitor’s refresh rate
  • Quickly modifies files on the disc & easy to customize settings
  • Removes any restriction like copy protection, encryption, or region code automatically
  • It eliminates any warnings, forced subtitles, trailers, etc.
WHAT WE LIKE
  • User-friendly software
  • Supports HD DVDs for quality viewing
  • Easily removes region codes and copy-protection
  • Operates seamlessly in the background without interruptions
WHAT WE DON'T LIKE
  • Time-taking ripping process
  • It is incompatible with Mac and Linux systems
Comparison of all DVD Decoders
Let’s look at these DVD decoders at a glance to compare them on some common grounds and find out which one is the best.
DVDFab DVD Ripper
WinX DVD Ripper
VLC Media Player
MakeMKV
K-Lite Codec Pack
AnyDVD
Decode protected DVD
Yes
Yes
Yes
Yes
Yes
Yes
Converts DVDs to video/audio
Yes
Yes
Yes
Yes
Yes
Yes
Hardware acceleration
Yes
Yes
No
No
No
No
Built-in Video Editor
Yes
Yes
Yes
No
No
No
Upon analyzing the chart, it becomes evident that each of the 6 DVD decoders possesses distinct advantages. Therefore, your selection of a DVD decoder should align with your specific requirements and preferences.
Why Is Your DVD Not Decoderable?
Earlier Windows versions had built-in DVD Decoders, but the newer ones, like Windows 8/10/11, do not have one. This is why you get a prompt saying that compatible DVD Decoder is not installed on your PC/computer, and hence, you must get an external DVD Decoder separately.
Does Windows 10/11 have a DVD decoder?
No. Windows 10/11 has no pre-installed DVD decoder in the Windows Media Player.
The Bottom Line
Incompatible DVD decoders are annoying, especially when you need to watch your favorite DVD on your media player. Nothing is more irritating than an outdated driver or a broken DVD drive. In such a case, you can use third-party compatible DVD Ripper to remove the copy protection and delve into a seamless playback experience.
